Old April 26th 2003, 04:45
paul_f's Avatar
paul_f paul_f is offline
944 master cylinder - brake light switch?
I am going to use a 944 master cylinder - not sure how to plumb in the brake line switch?
How have other people done it?
This is on a bus - however I think it would be the same on a beetle.
Thinking of using a T from the rear line and fitting the sensor here - but not sure if that would cause a leak or not?
Regards
Paul
Old April 26th 2003, 04:52
paul_f's Avatar
Ah just found a picture on Ricola's website.
Regards
Paul
Old April 28th 2003, 07:37
You can use the T peice that is used on the rear brake line, same thread.
Steve C
