Old April 27th 2003, 18:33
super vw super vw is offline
Porsche 911 style dash for 1303? (in the US)
does any one make a porsche style dash here in the states?
Old April 27th 2003, 20:48
Carbon Joe's Avatar
Carbon Joe Carbon Joe is offline
If I get my hands on one I'll make them.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old April 27th 2003, 21:33
carbon fiber would be cool, but only if its not to expensive (over 250) :P
hey Joe, can you make a sheet of carbon fiber thats thin enough to cut with a utility knife(1mm or .5mm?) On my Audi 4000 i want to make some accents around the guage cluster.
Old April 29th 2003, 08:46
Carbon Joe's Avatar
Yes, the thinnest sheet I can make is about .58mm (.0228) just let me know the size you need ? X ? and I'll let you know the cost.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old April 29th 2003, 18:33
well i need two sheets that are (4 1/8" by 4 1/8").
i have ordered a sheet from you before.
Thanks!
Jonathan
Old May 2nd 2003, 19:57
Old May 2nd 2003, 23:08
Carbon Joe's Avatar
Jonathan,
It's $25.00 with shipping for the two 4 1/8" by 4 1/8 sheets.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old May 2nd 2003, 23:35
can this be cut with a utility knife?
Old May 4th 2003, 10:50
Carbon Joe's Avatar
Well it can be trimmed with tin snips or a good pair of scissors, but if you want to cut holes or windows in them then no. You would need a dremel with a diamond wheel, even though it's thin (.023) it's still very very tuff stuff.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old May 4th 2003, 13:50
bummer, i was thinking of using a Olfa circle cutter that uses a sharp exacto like blade. so i guess i might hold off on using CF for material.
Old July 10th 2003, 19:09
Vincent's Avatar
Vincent Vincent is offline
911 dash
A few years back I saw a company that built a early 911 dash for a 1303 I looked back through my links but can't find anything... I would love a 911 style dash out of Carbon...
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
Old July 10th 2003, 19:51
Yeah, a carbon one would be slick! also expensive i would think
Old July 10th 2003, 20:01
MattKab's Avatar
MattKab MattKab is offline
A masterpiece
Old July 10th 2003, 20:58
Vincent's Avatar
where did you get that pic?
I saw a company a few years ago that made an early 911 style dash for the 1303... have not been able to find them online any more. It would be cool to have it with the key on the left like the 911 also.
Vincent W. Strader
plans
Old July 10th 2003, 23:48
Alex's Avatar
Alex Alex is offline
Hoffmann in Germany sells them too and Remmele makes them in Carbon Fibre.
