Old April 30th 2003, 13:17
havik180 havik180 is offline
MaXX question
I recently rebuilt the front suspension on my 72 complete with MaXX's ,disc's,bushings,ball joints,tie rods etc... I put the stock wheels back on for now and when I set it on the ground the pass side seems a bit lower ! The struts ARE adjusted to the same height. It also seems that the pass. side wheel is a bit farther forward . What could the problem be ? Alignment ? or ??? Anyone else have a similar problem ?
Old April 30th 2003, 21:51
Superman
Yes the alignment could cause this, also the fenders could be different. OEM and aftermarket fenders (and fenders made by different manufacturers also) do differ in shape.
Old April 30th 2003, 23:57
lightning bug's Avatar
After you change your suspension, especially front, you should get an alignment. I'll agree that that's your problem.
Julian
'74 Super
