Old May 2nd 2003, 08:06
Rob's Avatar
Rob Rob is offline
Brake Booster
I just read that some Busses came with brake boosters.
Would it be possible to use one of those boosters on a bug ?
Anybody ever done this ?
I thought these things were activaed by vacuum, so I guess you would either have to run vacuum lines all the way to the front, or put the booster in the back....
Any info is welcome....
Rob.
Old May 27th 2003, 18:25
Michael Ghia's Avatar
I fitted a servo (booster) to my Oval a while back and put a short article on the PG website (http://www.performanceghia.com) but it is not easy and really shortens the turning circle the way I fitted it.
If I were to do it again, I would use Porsche pedals and use the system they use on the pre-89 911 where a link rod is used from the brake pedal to the master cylinder and servo which sits facing rewards infront of the dashboard.
MG
