Old August 19th 2002, 11:27
bren's Avatar
bren bren is offline
carbon headlamp surrounds and turn signal covers
ive spoken to joe about some parts i want for my bug and thought id also post on here to see if others would want the same parts on their rides.. im after H4 (late style) single screw headlamp surrounds... would look rad on a late 'looker IMO.. im also after some euro spec turn signal covers in c/f .. the wingtop kind (fender top!)
so who else would want them? the more interest, the more chance of having them made!!
Old August 19th 2002, 11:46
Alex's Avatar
Alex Alex is offline
Hmmm some lamp rings for the pre 67 and later style headlights would be cool.
Great idea.
I will take a set of the early style headlight rings if they will be available for sure.
Joe.....would you need originals to make a mold for that?
Old August 20th 2002, 09:44
samcat's Avatar
samcat samcat is offline
Late style headlight rims with single hole. Put me down for a set
Sam C
Old August 20th 2002, 10:03
bren's Avatar
cool.. thats two then.. any more for any more?
Old August 21st 2002, 00:45
kohi30
put me down for a set of the headlight rings. how about carbon fiber fender guards?:
Old August 21st 2002, 03:43
69_Dreamz
Im with kohi30 on that one about the fender guards. I say a Remmele Byg (excuse the spelling if incorrect) with them and it look great!
Old August 21st 2002, 03:46
AlphaC AlphaC is offline
I could use a set of carbon headlight rims too
Old August 21st 2002, 03:49
kVinyl's Avatar
kVinyl kVinyl is offline
I'd be interested in both the wing-top indicator housing and the headlamp surround - good idea!
Old August 21st 2002, 04:04
69_Dreamz
Question
How well does carbon fiber hold up to the outside elements? I mean does it crack or discolor from being in the sun? Is it affected by salt air or humidity?
Old August 21st 2002, 06:29
bren's Avatar
hell yeah! stone guards for the rear "fenders" would be way cool too!! thats a 'must-have' on my bug!! FYI the remmele cars you see dont actually have stick on stone guards, they just leave that section of the carbon "fenders" unpainted...
Old August 21st 2002, 08:39
Carbon Joe's Avatar
Carbon Joe Carbon Joe is offline
Exclamation
OK I'll do them, this weekend I'll get the parts together and start working on the molds. This the type of response I need if people want me to make special parts, if I know more then three or four people want something made I'll make it. A set would look nice on my car to, also stone guards are in the works.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old August 21st 2002, 08:53
Carbon Joe's Avatar
Wink
69_Dreamz,
Carbon fiber holds very well to the elements if it's made right, I use a UV resistant resin in my parts. Once the parts are cured water, salt, oil or just about any other chemical will not harm the part.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old August 21st 2002, 09:53
Thumbs up
Put me down for a set of early trim rings !
Old August 24th 2002, 13:05
RotoGhia's Avatar
RotoGhia RotoGhia is offline
headlight rings
me too These would look cool!!!!!!!! I'll take a set!
blue
70 Karmann Ghia Custom
56 Beetle GL under construction
53 Studebaker Truck Rod
Old August 24th 2002, 14:31
ill take a set of the later headlight rings also...
& some of those fender guards too
