Old May 24th 2003, 07:55
1302super's Avatar
1302super 1302super is offline
can i fit these wheels to my 66bug
7.5 front
7.5 rear
porsche turbo cup et 55
ive a 66 beetle will these fit
Old May 27th 2003, 12:17
JasonH JasonH is offline
yes. with modification.
Old May 28th 2003, 07:34
dgluyas's Avatar
dgluyas dgluyas is offline
turbo wheel fittment
The turbo wheels come in different ETs depending on if they are aftermarket copys or original Porsche equipment. What is the ET on these wheels? You can find it on the inside of the wheel.
For a bug with standard guards and suspension with wheel ETs about 55 mm fronts and 47mm rears and you should be ok.
"Goliath"
Old June 5th 2003, 11:27
1302super's Avatar
the wheels r 17 f&rear et55 and r 7.5 wide
will these be ok?????
Old June 5th 2003, 21:11
dgluyas's Avatar
Yeah ! Those wheels should be fine with a standard setup.
Good luck .
"Goliath"
