Old May 26th 2003, 23:39
btljus btljus is offline
Flipping the front swaybar?!
Has anyone done this sort of thing (succesfully) on a balljoint front end? I am going lower in the front on my '68 standard beetle and heard that the sway bar can be flipped to sit on top of the lower arms instead of the bottom for better ground clearance. I currently have a 3/4" (20mm) bar and it is installed on the bottom. Are there any tricks or different mounts that are needed to do this?...I started fitting the bar but it won't clear the nut that holds the arm to the beam on the drivers side, the pass side will fit cuz the nut is on the bottom. Don't know if it makes any difference, I have the BugPack sway bar with urethane bushings.
Peter
www.beetlejuice.ca
