Old June 2nd 2003, 14:50
havik180 havik180 is offline
Would it still be German Look if.....
Would you still consider a bug a GL if it had a (Wankel) Rotary in it ? Remember Felix Wankel was German so does that mean the rotary is ok because It has german roots ? Just curious about your opinion.
Old June 2nd 2003, 14:53
I would think so.
The german look is about making your car better then when it was first made. Form has to follow function.
As long as the converion was properly done, I dont see why not.
Old June 2nd 2003, 20:53
lightning bug's Avatar
Ther are GL's with Subaru engines. So if that's considered GL, Rotaries should definitely.
Julian
'74 Super
Old June 3rd 2003, 02:46
Yes, sure. The Wankel is also quite an advanced piece of engineering and that is also what GL is about. Mazda is still perfecting the concept and gets very high hp out of them, turbo'd and all. Very compact design; ideal for a small engine compartment like a ....beetle (!?).
Good luck,
Old July 10th 2003, 20:55
Vincent's Avatar
Vincent Vincent is offline
That is good...
I am working on a 1303 with a 13bt going to try to use the rx7 ac also... that will be very cool in the hot texas summers... I have a lot of planning to do. I have a 73 1303 right now but it is in bad shape someone stole the wheels off of it and the back windows. It may still work but I want to get just a 73 03 runner to drive for a bit as I am planning my project.
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
