Old August 20th 2002, 19:51
greenterbo's Avatar
greenterbo greenterbo is offline
Question wheel spacers and studs
Need help with wheel studs. I installed the 944 disc brakes on the rear and found that with the spacer the wheels stick out to far. removed the spacer and it's better but now the studs are to long. Do I even need to run a spacer at all? How do I determine the length of the stud required?
Old August 21st 2002, 03:39
69_Dreamz
Why the spacers to begin with. The only time I have ever seen spacers used is when the tire or rim was hitting either the brake assy. or the shock/bump stop. If the studs are too long, take the rotors to any machine shop and have them cut )if they are pressed in), if they are screw in , change them. Most Hotrod shops will carry studs varying in pitch and length.
Old August 21st 2002, 04:00
Superman
The 944 comes factory with rear spacers. What wheels do you plan to use?
Old August 21st 2002, 07:16
stud length should be 2-3 times the diameter of the stud if using alloy nuts. so a 14mm stud...you want 28mm of thread min.
Old August 21st 2002, 08:04
Or you can measure the thickness of the spacer and deduct that from the length of the stud. That's what I am going to do tonigh for my lovely fully polished 16" fuchs
Old August 21st 2002, 11:41
greenterbo's Avatar
I have a set of Boxster rims (16") w/ Michelin tires. In addition the stud issue, another problem I face is the tires are made to be wider than the rims. I measured the tire width (9") and the offest of the wheel from the edge of the tire (6 1/4") and the distance from tire to wheel (3/4"). The wheel is 7.5" wide. These are for the rear only, fronts are 6" (me thinks). As you know Superman, body is not yet on the pan (picutes on SBO website, members). I measured from the body mount on the pan to the edge of the tire w/ spacer (12") and w/o spacer (11"). Still I am 1 inch to wide. I may have to get different tires. I will have to see once body is on the pan. It appears the studs are pressed in, 944 hubs, is this true? Years ago when I had a 68 Nova SS, I broke wheels studs and w/ my Dad's help knocked out the old ones and fitted new ones. What's the big deal? It should be an easy swap, yes? Maybe I should have machine shop press out old and press in new?
Old August 21st 2002, 14:46
MattKab's Avatar
MattKab MattKab is offline
I fitted the studs from a '87+ 944T hub to the '86 944T hub and left off the 21mm spacers. Rear tyres measure 225/45ZR17 and wheel offset is 52mm. Everything fits
Old August 21st 2002, 18:10
hot66's Avatar
hot66 hot66 is offline
whats the difference between the early & later hub?
please see my post in the 'wheels' section, as I'm trying to get my backend to fit
http://www.germanlook.com/Forums/sho...=&threadid=237
project in progress
Old March 4th 2005, 19:50
VWader04's Avatar
VWader04 VWader04 is offline
i need to replace my wheel studs..what size should i order? 45mm? 66mm?
84' 944 n/a hubs...
cup 3 rims
the ones in the hubs are too long...looks like someone ran a 1" spacer.
i need to get some to allow fitment under stock fenders.
what is the stock length?
Old March 4th 2005, 20:53
vw1303's Avatar
vw1303 vw1303 is offline
I had the same problem when running 944 brakes. I used a hacksaw and cut off 20mm(the thickness of the spacers). You could buy theh studs but studs are expensive(compared to a hacksaw blade) .
