Old June 12th 2003, 05:03
effvee effvee is offline
Exclamation will 944 brakes fit under stock front fenders?
Hay Superman, thanks for the info. Question, will the front spindle of a 1985 944 fit within the fenders of a stock 1303 fender?
Old June 12th 2003, 05:15
Superman
Yes! The track will widen 10mm, per side and you can fit up to a 7.5" wheel with 205 tire.
Old June 12th 2003, 07:47
Supe
can the 944 turbo brakes be adapted to use on a 1303 front suspension with Kerscher ball joints?
or is it only 944 na brakes?
Old June 12th 2003, 09:31
Superman
Yes (MattKab & I have them on our 1303), the Turbo brakes mount in the same fashion and the ball joint is the same; however the spindle mount differs from the NA and is a slight problem. Note that the late Turbo S has a 19mm ball joint.
Please refer/reply to this thread on the Turbo brake topic
Old June 12th 2003, 14:33
Big thanks
Superman, thanks its really nice to have someone out there like yourself, again thank you
effvee
aka Francelle Vercher
