Old June 13th 2003, 19:59
smitty smitty is offline
clutch options
I nhave a rail with a 1700 type-4 with a 210mm set up.I need a new clutch ,what are my options?Cant find anything local will have to order.Will stock be my only option?And where is a good source to order from?Thanks Smitty
Old June 14th 2003, 09:42
stock 210 should be enough. and you can use a 200mm disc if you want wider set of options there.
