Old June 15th 2003, 09:09
kuna's Avatar
kuna kuna is offline
Porsche fan/engine number
hi, this summer I`m planing to convert my 1303 to T4 power. I`m going to use 73-78 bus engine with B.A.S, CSP or KNUF Porsche fan, I know that case machining is required... but... won`t it destroy engine number? can engine number be seen easly (without removing cooling system) after converting to Porsche fan?
and BTW whith engine will suit best my needs (2.0L, about 120PS, dual 40s, 280-290 cam) ... year/engine leters please...
thanks for help !!!
Old June 16th 2003, 04:32
Michael Ghia's Avatar
Yes it destroys the engine number... but hey nobody over here seems interested in the engine number of a Beetle.
MG
Old June 21st 2003, 03:34
nbturbo's Avatar
nbturbo nbturbo is offline
Engine number
What I did was file a small flat surface on the case where that long bolt goes through just below the Porsche fan-then sand it smooth and restamp your engine number-you need only to borrow some letter and number punches.
