Old June 17th 2003, 10:31
Don't tell my wife that I bought....
another VW
she will probably be mad
I just bought a 74 1303 Sunroof model.
It appears to be structurely sound so I may use this car for my
German Look project instead of my 1302.
If it ends up not being good for my base project, I will probably
strip the 1303 and cut the roof off for the steel sunroof to use on my 1302.
Old June 17th 2003, 12:12
Thumbs up
sweeeeeet. post some pics when you can.
Old June 17th 2003, 12:42
I will try.
For some reason my digi camera wouldnt work yesterday when
I tried to take some photos & I even changed the batteries with
ones I had laying around. I guess its possible they were bad too.
Old June 17th 2003, 17:44
Cool, you almost have as many VW's as I do.:silly:
Old June 17th 2003, 21:51
After assessing the damage today, I am leaning towards stripping the 1303 of all its good parts & using the 03 suspension on my 02. I would probably sell the rest of the parts that I dont need.
The 03 also has a factory steel sunroof and I would probably cut it off the 03 and graft it into my 02.
I havent made my final decision yet, but I will keep you guys posted.
Old June 18th 2003, 07:03
Is the roof line of the 03 the same as the 02? May want to check before you try and swap the sunroof.
I picked up my 03 front suspension this weekend (along with a few ticks and some poison ivy ), so we can all work together on doing this swap, see what we can learn.
I've looked into making a bushing for 944 spindles to adapt to the 15mm bug ball joint, so we don't have to get the 17mm kerschers.
When do we get pictures?
63 356b time capsule
948 project
Old June 18th 2003, 08:55
John
I cant get my digi camera to work for some reason.
The roof line is the same all the way up to the front windshield I believe. A competant bodyman should be able to graft it in.
Btw John I need to talk with you about something on the phone.
