Old June 17th 2003, 10:33
Bad bug's Avatar
Bad bug Bad bug is offline
914 heads
Hi, vujade Where can i find a set of good used heads for the 914 .
Old June 17th 2003, 10:39
Do you want 2.0 914 heads or 17/1.8 914 Heads?
I dont have any more 1.7/1.8 914 Heads but I do have 1 pair of 2.0 914 heads and I am probably getting another set of 2.0 914 Heads in about a week.
If you are interested in the 2.0 914 heads let me get this other set I am waiting on and I wll contact you when I get them.
Old June 17th 2003, 11:05
Bad bug's Avatar
914 Heads
How much do you want for these heads. Can these heads be bored out to fit 101mm sleeves. By the way i would like the 2.0l 914 heads.
Old June 17th 2003, 11:49
yes they can be used with 101mm sleeves.
I have seen these used with 103's before.
As far as price is concerned, let me get this other set before I give you a price. I dont know what they are going to end up costing me with shipping yet.
Old June 17th 2003, 21:08
Bad bug's Avatar
Type 4 engine
What size engine do you have in your car.
Old June 17th 2003, 21:35
I currently have a 1600cc T1 in my car.
I am going to build a 2056cc T4 (96 x 71)
Old June 18th 2003, 02:49
Bad bug's Avatar
914 Heads
Why not a bigger engine in type 4. What kind of horsepower can this engine give.
Old June 18th 2003, 06:44
Mario.D Mario.D is offline
Question 914 head$ Vw head
I Vujade,wich diference have 914 heads versus Vw type 4 2L
head?
Is a compression rate or valve size too.?
Thank you for your help.
Mario.D
Old June 18th 2003, 09:01
Bad Bug,
The reason I am going with a 2056cc for now is that I fell into the parts for a really good deal to make this engine.
I will go with a bigger T4 down the road once I complete my car (paint, interior, etc).
The 2056cc T4 should make around 130hp properly tuned.
Mario D.
The 914 2.0 head uses larger valves (42 x 36) vs Bus 2.0 (37 x 33) and it was set for higher compression 8.0 : 1 vs 7.3 : 1
