Old June 18th 2003, 11:14
petevw's Avatar
petevw petevw is offline
what size/kind of oil pump is right for me?
what size/kind of oil pump is right for me? which kind?
this is what i'm already running:
2332
drysumped
cummings pump
plumbed with 3/4
sees 8000rpm
i think i damaged my oil pump (stock size?) when taking it out last time. i have a leak in between the pump and block ONLY when i turn it off. it pisses out a little then stops, with no pressure just pours like its draining. so im looking for a replacement ? im probably going to silicone it tonight for the time being.
your thoughts?
thanks,
pete
'72 super
'65 bus
'52 split
Old June 18th 2003, 11:39
Tim Tim is offline
What is the application of your car/engine? If budget permits, I would go for drysump. The only problem is where to put the oil tank if yours is a street car.
Tim
Old June 18th 2003, 13:14
petevw's Avatar
sorry i guess i wasn't clear.
the car is drysumped already. it's driven on the street/strip. the car is together. i need to replace my oil pump and don't know what to replace it with. what's available? recommended?
pete
'72 super
'65 bus
'52 split
Old June 18th 2003, 13:59
Tony Z Tony Z is offline
I know PTP in Germany has a few kinds. Otherwise, if memory serves, CB perf has a dry sump pump also
1969 VW aka Suicyde
www.geocities.com/suicyde_vw
Tony__Z@hotmail.com
Old June 18th 2003, 15:19
petevw's Avatar
i have the dry sump pump.
the dry sump pump bolts and is squished onto the stock oil pump. its the stock oil pump i want to replace. the part that sinks into the case. the drysump pump itself is ok.
i see 26, 29, 30mm pumps on the net. i know nothing about these pumps. this is what i'm inquiring about. or i can replace it with a stocker. i don't know.
pete
'72 super
'65 bus
'52 split
