Old June 20th 2003, 18:09
Bad bug's Avatar
Bad bug Bad bug is offline
101 Piston and sleeve
Hi Guy's,
I would like to know if it's a good idea to use 101mm piston in a daily driven type 4 motor, crank size would be 71mm.
Old June 20th 2003, 19:55
not unless you are planning on using Nickies.
Otherwise you wont get more then 20-30,000 miles out of that motor with regular pistons & cylinders.
Old June 20th 2003, 23:27
Bad bug's Avatar
Engine choice
What's the best setup for daily driving.
Old June 21st 2003, 00:06
Tom Alltypes's Avatar
Tom Alltypes Tom Alltypes is offline
Depending on your budget, you can get great reliability out of warmed up 2 liter, a 71x96, or for some more $$$, 78x94 or 96. Set your budget 1st, then match your wish list to that.
Tom Alltypes
Tom's Old VW Home
