Old June 29th 2003, 22:10
BWE BWE is offline
Question Local (Canadian) source for door solenoids?
Hey Guys, Sorry this is a bit of a tech question, but I'll put it here anyways.
I'm looking for a Canadian (Ontario would be even better) source for door solenoids, the bigger 35lbs ones. I installed mine into my doors last night and they won't even budge the latches! They're only rated at 12lbs.
Any help would be great since I can't shut my doors with the windows up at the moment.
Thanks all,
Dave
'70 GL Bug, T4 Powered!
www.boxerautogruppe.ca
Old June 30th 2003, 16:08
petevw's Avatar
petevw petevw is offline
try and contact: btljus (Peter) on this forum. i'm sure he can get a set of domestic solenoid clunckers. he's got them on his bug.
later,
pete
'72 super
'65 bus
'52 split
Old July 7th 2003, 14:33
btljus btljus is offline
Here I am! LOL, I'm using an AutoLoc set. But the solenoids don't look any different than those found in a Mr Gasket (ones I sell at work) 12lb kit. I have no clue as to why yours aren't working! My buddy has them in a '94 T-bird and I just sold a set last week to a shop they put them in a Suburban and that worked just fine! In a bug you need to make up a pulley system ar find a better spor to mount the solenoid. What I did is extend the rod from the door so that it's easier for the solenoid to pull.
Peter
www.beetlejuice.ca
Old July 7th 2003, 16:35
CLKWRK's Avatar
CLKWRK CLKWRK is offline
hey,
if you are poor like me........
find an old jag from the 80's at the wreckers and hack the door solenoids outta that.
They are good quality, magnetic and perfect for shaved door handles. Thats what I am using, I got mine for $20.00cdn each.
BRY
GL ghia restoration:
Old July 8th 2003, 07:54
BWE BWE is offline
Thanks folks,
I tracked down an old set of Spal solenoids that a local shop had special ordered for someone 2 or 3 years ago... The guy prepaid the shipping but never picked them up! The shop owner just wanted them out of the way so I got them at a good price.
Thanks again for all your help
See you all tonight!
Dave
