Old July 1st 2003, 18:46
llmadll llmadll is offline
Type 4 motor question
is it passable to put a type 4 motor on a 71 trans if it is how???
Old July 1st 2003, 23:32
kdanie kdanie is offline
Are you talking about a type 1 transmission? If you are, yes it can be installed, quite easily. You need a 210mm or 215mm type 2 (bus) flywheel/clutch/pressure plate. The pilot bearing that normally goes in the crank needs to be fitted to the hole in the flywheel. The release bearing must be compatable with the pressure plate. There is a slight hang up with the release bearing cross shaft on some years but I don't remember what that is.
I highly recomend spending the $$ for the "Next Generation" manual, it covers all this very well. I sold my manual to another forum member when I decided to install a Porsche 5 speed so I don't have the address. I'm sure someone will chime in and help.
ken
Old July 2nd 2003, 07:21
next gen
here is some additional reading on TIV (see learning and literature). just realized we forgot to put Next Gen on there. will fix that.
