Old July 6th 2003, 21:51
NCbug NCbug is offline
carbon fiber floor pans
this may sound like a stupid idea i donno , but i figure they r light ,they wont rust or rot . would anyone be willign to make something like this?
Old July 7th 2003, 08:30
bring your wallet. i am sure they can be done for the right price. plan on upwards of $150-300 each side.
Old July 7th 2003, 10:03
Chris Percival's Avatar
Attaching them to the chassis would be too difficult..
Old July 7th 2003, 12:18
couldnt you just bolt it on to the chassis?
Old July 7th 2003, 12:21
I am sure it wouldn't be strong enough...
Old July 7th 2003, 12:51
if they can make fiber glass floor pans i am sure that carbon fiber obes can be done too,
Old July 7th 2003, 18:09
Superman
They could probably be molded in like the fiberglass ones, but...
crash-bang-slam > the seat track frame just cracks and people are going to fly
Old July 7th 2003, 18:33
damn i didnt thinka the seat tracks
Old July 7th 2003, 19:10
Hello-
Make it like a late Type 3 - weld the inner seat tracks to the center tunnel and the outer ones to the heater channels. On a late Type 3, the floor pans are nothing more than just floors (and, of course, chassis stiffening members)...
Take care,
Shad Laws
Old July 16th 2003, 02:02
Carbon Joe's Avatar
Carbon Joe Carbon Joe is offline
It can be done, but the tools would be the big cost. Two tools that big would cost around $2000.00 each.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old September 14th 2003, 22:04
Michael Ghia's Avatar
Carbon floor
I have been working on a car which has a Carbon fibre floor in it, it was bonded in and no, nothing is mounted to it. the seat runners etc all have their own supports which stem from the inside of the sills. The tunnel is also Carbon Fibre, bonded onto the floor.
One thing though, it's not a Beetle!
Mike Ghia
Old September 15th 2003, 12:25
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Michael,
These hints about floor pans and engine pictures are killing me. So when will you show us what you are working on?
Hurry,
Randy
Old September 15th 2003, 14:03
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Hey guys
there is no steel in my floors, my seats are bolted to the tunnel and the heater channel. It works well
Bry
GL ghia restoration:
Old October 1st 2003, 23:07
ashe ashe is offline
ok guy's, hate to be the one that sounds like an ***, but making carbon floor boards is not a diffucult process(notice i said diffucult, cost is another issue). the correct way to do this is the same manner as formula one cars. what you need is aluminum honeycomb. what it is aluminum about as thich as foil. this is arranged on end in the shape of a honeycomb. this honeycomb is then sandwiched between two sheets of aluminum. the process starts by laying down several layers of prepreg carbon cloth, then the aluminum honeycomb, followed by several more layers prepreg. carbon sheet by it self it torsionally rigid enough to take that kind of load, plus, if youve ever hit a piece of carbon you would know that it cracks. thus the seat problem. by using the honeycomb you gain the shock stength and added rigitity. plus attachment to the frame would be easy, you could bolt or bond, or even weld it in by leaving some aluminum sticking out. this cures all of the mounting problems, including seat. but theres alot to consider, especialy weave dirrection. formula 1 builders orient the direction of the weave in each piece made to in order to have maximum rigity.
Old October 3rd 2003, 22:56
Sounds interesting... I think the Panoz LMP900 runs a honeycomb chassis but will have to look at the car again in detail if I get a chance.
The car which the carbon floor is in is a 911. It's bonded in but looks metal until you tap it! then it's easy to tell. The same car has a carbon roof, wings (fenders) and lots of trick stuff.
MG
