Old July 8th 2003, 04:34
samcat's Avatar
samcat samcat is offline
Drilling holes in Carbon Fibre?
What is the best way to drill a hole in carbon fibre so that it doesnt crack?
What should be done to the hole to make sure it doesnt fray/crack after being drilled? Someone said to me 'superglue' last night... Is that right?
its for my firewall... I have an MSD 6AL, Blaster 2 coil and an oil catch can I need to mount.
Cheers,
Sam C
Old July 8th 2003, 11:44
bren's Avatar
bren bren is offline
lay the sheet over some wood or MDF as support and something to drill into, use a NEW drillbit and just drill! ive not seen c/f fray ever.. but paint or superglue would seal the edge if you can be bothered.
Old July 8th 2003, 12:29
samcat's Avatar
Cheers Bren,
Done some research of my own and the recommendation is to use carbide tipped drills (which we have some of ) and to take it slow. Smallest drill first than gradually work your way up in sizes.
I will superglue the edges for additional protection too.
Cya,
Sam C
Old July 12th 2003, 01:41
Vyper Vyper is offline
Originally posted by samcat
Cheers Bren,
Cya,
Sam C
I think you're being too technical there Samuel (there's a suprise! ) Just drill the f*cker and be done with it!!
The firewall is so thing that you can cut it too with good quality snips!
Vyper
The Future's Bright....
The Future's Tomato Red!
