Old July 17th 2003, 07:37
AcyTom AcyTom is offline
Talking My rear disc (pic)
Hi!
Here is my rear disc conversion!
http://vw1303s.tripod.com/1303s/id15.html
But!
Do I have problem or not! I cut my old drum break to put in golf I front disc.... but now when I rotate wheels.... wheels had +- 1 mm at radius 7.5 inch play left right..... Is this a lot or I must again relined hubs....
Regards from Croatia!
Tomica!
Old July 19th 2003, 08:28
Jim Andritsakos's Avatar
Hello AcyTom!
Well, they should have NO play at radius rotation...
Have the hubs vey carefully resurfaced but check also : is the discs brand new ? if not maybe they need a very very light 001mm resurfaced in the inner surface too.Are you bearings in good condition ? Are the hub main bolt properly torqued ?
Give me some more details about the setup for additional info.
The red/black kombo looks great!
Good luck
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
Old July 22nd 2003, 02:45
Hi!
Thanks for your answer I check all stuff but the problem is that the hubs has +-0.2mm endplay, so I must carefully resurfaced hubs.....
I'm working on my beetle for last 2 year and everything I had to do twiced.....
Regards !
Tomica
