Old July 22nd 2003, 23:42
ShApE's Avatar
ShApE ShApE is offline
DO NOT LOOK IN HERE!!**invite only**
ok so since no-one answered my last thread i decided to trick u and it worked. so any information on raby's 2270cc kit? is it hard to install. price range? any info appreciated!
-= 71 super =-
-= 86 944 turbo =-
-= 84 911 carrera (dad's) =-
-= 99 ford explorer =-
-= 2005 Cayenne S =-
Old July 22nd 2003, 23:55
Vincent's Avatar
Vincent Vincent is offline
looks like no one knows...
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
Old July 22nd 2003, 23:59
ShApE's Avatar
dayum....
-= 71 super =-
-= 86 944 turbo =-
Old July 23rd 2003, 00:28
jrinlv jrinlv is offline
Do you have any parts for cores? 5-6 k is what I would plan on spending, If you really need to know drop Jake a line.... Thats what I would do if I wanted an engine from him (he would know best) My 2 JR
Old July 23rd 2003, 07:38
Rob's Avatar
Rob Rob is offline
I think there was a tread about this at the shoptalkforums....migth want to check it out...
Rob.
Old July 23rd 2003, 12:15
ShApE's Avatar
alright thanks
-= 71 super =-
-= 86 944 turbo =-
Old July 23rd 2003, 18:03
Jake is on vacation.
The kits cost about a grand less than if it is assembled I believe. Thats not much considering that the turn key version is dyno tuned. and the kit is not. Jake doesn't throw a bunch of parts in a bag and call it a kit. The kit is basically assembled and taken apart again so he knows it fits, properly clearanced and all that. I'm suprised he doesn't charge more than the turn key considering he has to disassemble it for you.
Ron
Old July 23rd 2003, 22:51
ShApE's Avatar
alright i have a new question : i was wondering will whats the highest i can go on here without having to do any machining to the case. i know it says 88mm and larger requires machining but is that still true on a type 4? click here.
-= 71 super =-
-= 86 944 turbo =-
Old July 24th 2003, 00:06
well a 2.0 t4 case had 94's, so that is already larger then 88's.
You should be able to use 96's no problem I believe.
Old July 24th 2003, 00:08
ShApE's Avatar
mines not the 2.0 i got it out of a 72-73 bus so i think 1.7 or 1.8
-= 71 super =-
-= 86 944 turbo =-
Old July 24th 2003, 02:11
Superman
ShApE, as per your request via private message I am posting a reply to this topic...
I have no knowledge nor interest in the aircooled motor(s). Personally my car has a Golf GTI motor and although I own a Superbug I am more of a "watercooled guy" per say.
Old July 24th 2003, 07:20
shape, what is the engine code on the case?
I can tell you the engine size if you give me the letters that are in front of the numbers.
You should be able to find these next to the crankcase breather tower
Old July 24th 2003, 10:36
ShApE's Avatar
the letters are CB
-= 71 super =-
-= 86 944 turbo =-
Old July 24th 2003, 10:50
CB is a 1.7 Bus motor.
It has 90mm pistons stock
Old July 24th 2003, 10:53
ShApE's Avatar
so what do u think is the largest i could go without machining?
-= 71 super =-
-= 86 944 turbo =-
