Old July 27th 2003, 14:25
Rob's Avatar
Rob Rob is offline
Sandblasting
Since I've got the engine out and cut out the rear apron, I'm trying to make the engine compartement look better.
The previous owner had an undercoating fetish and pretty much covered everything with the sticky stuff.
I've been able to get rid of most of it with paint thinner, but I'd really fell better if I could just have the whole compartement sandblasted.
Does any autobody shop do this ? Is it expensive to do ?
Can I have 'only' the engine compartment blasted ?
Any local shops you recommend ?
Rob.
Old July 28th 2003, 17:47
ShApE's Avatar
ShApE ShApE is offline
well i asked a question regarding sandblasting and from what got its not a very good idea. but i could be wrong
-= 71 super =-
-= 86 944 turbo =-
-= 84 911 carrera (dad's) =-
-= 99 ford explorer =-
-= 2005 Cayenne S =-
Old July 28th 2003, 18:02
Racelook's Avatar
Racelook Racelook is offline
Ow yeah it can be sandblasted....
I do hole the car by my own...especcialy al the inside corners where i cant come with my Dremel, etc.... But i work with not so high amount of Bar / Psi so there is almost no change that the metal is going to bend...
It also depends on what material the blaster use... with plastic blastmaterial you sercentanly don't get any bumps.
B-Extreme B-Tuning.....
Old July 28th 2003, 19:52
Rob's Avatar
Rob Rob is offline
Hey Shape, yeah, I saw your post just after I submitted mine
I was hoping somebody local could point me to a shop, but I think
I'll try it with a wirewheel first.
It's just there are so many corners in that engine room that makes it a PITA..
Rob.
Old July 29th 2003, 21:57
BWE BWE is offline
Hey Rob, you might want to try Universal Blasting Services. They are mobile and so will come to you. They do 'exotic' media blasting as well ie: soda, walnut shells, plasic pellets, etc. I've never used them but I'm sure they would be able to just blast the engine compartment. Office: 905.544.2666 or Mobile: 905.541.9994.
Good luck!
Dave
'70 GL Bug, T4 Powered!
www.boxerautogruppe.ca
Old July 30th 2003, 07:56
Rob's Avatar
Rob Rob is offline
Thanks Dave ! I'll give them a call.
Rob.
Old August 1st 2003, 12:08
Rob's Avatar
Rob Rob is offline
Looks like they are no longer in business
Rob.
