Old July 28th 2003, 00:04
70dragbug 70dragbug is offline
993 Brakes on a bug....Oliver?
Hi everybody!
I have a set of 993 Porsche brakes that I want to install on my bug.I´m aware of the conversion with the spindles,etc. but what about the master cylinder?Does the stock dual circuit master cylinder create enough pressure?Will I need a snubber valve/reducer for the rear brakes(also Porsche 993)?Thanks for the help
-Mark-
Old July 28th 2003, 16:19
Tony Z Tony Z is offline
I dont run porsche discs, but I do have golf discs all round, golf 1 rears and golf 2 fronts. Anyway, my master cylinder was too small. My mechanic, who designed the conversion, then installed a master cylinder from a VW bus. The later bus with the 2.3l 5-cyl audi engine. Dont know if you guys ever got those, but it was the newer version of the classic bus, with the engine still at the back and shaped like a brick.
1969 VW aka Suicyde
www.geocities.com/suicyde_vw
Tony__Z@hotmail.com
