Old July 29th 2003, 22:17
LOAF's Avatar
LOAF LOAF is offline
Flip Kit
Finally got everything I needed for the 944 Front conversion.. minus Kesher Ball joints.. Somewhere in the mail.. Just finished drilling the holes on the 944 spindles for the flip-kit..(tie rods), and I can't find the post that mentions if they go on top or thru the bottom.. Please help.. Guess I will finish tomorrow.. Having a Drill Press Rocks.. Haven't had this much fun since High School Shop Class. Sorry to vent.. But finally having some fun..
ALex
also a
Old July 30th 2003, 10:47
MattKab's Avatar
MattKab MattKab is offline
The trackrod ends will fit into the new bush from above the steering arm, tapered stud pointing down.
Offer the new bush to the tapered stud on your trackrod, so you can determine where the castlenut/splitpin hole will be once they're installed. You may have to modify them (in length) slightly- I did, tho' mine were bought in plain packaging from a trader at a VW show.
'hope that helps,
Matt
