Old July 25th 2002, 19:26
lightning bug's Avatar
Question 915 box to T1 engine
Has anyone mated a 915 trans to a type 1 engine. I see it alot with T4's, but not with T1's. I understand that Kennedy makes a flywheel for this conversion. I think I can handle the mounting. The "push type clutch" worries me though. I plan on using a hydraulic set-up. Any tips or suggestions about this conversion would be greatly appreciated. Thanks!
Old July 26th 2002, 14:08
dobergoose's Avatar
dobergoose dobergoose is offline
My engine is in the states being built by Marty Staggs who bought the Kennedy Flywheel which uses the porsche clutch.
Box is a 915 but I haven't used it yet.
Old July 26th 2002, 17:20
Thanks dude. I just got off the phone with Kennedy. My flywheel should be here in about a week. I still have the "pull type" clutch problem though.
Julian
'74 Super
Old July 31st 2002, 20:20
I've just got a line on a trans. I'm hoping to post the install as soon as I can find time to install.
Julian
'74 Super
