Old August 21st 2003, 17:29
1915 cc, whats up?
ok i found this 1915 cc long block on ebay from www.importmotor.com . for 935.00. this is what it has.....
reman. case
new 042 big valve dual port heads for unleaded gas
40 /35 valves
new pistons and cylinders 94mm
reman 69mm crank
110 crank 400/284
lightened flywheel
high capacity oil pump
is this any good?
ive never built an engine, so what gives? with these heads for unleaded gas would that be a CR of 7:1 or what?
please help
neil
Old August 21st 2003, 22:20
kdanie kdanie is offline
This is just my view.... The 110 cam is too small but will make great torque. I would run the compression at 8.5-1 if it was me.
Otherwise it souns ok...
ken
Old September 12th 2003, 07:05
regis101 regis101 is offline
Just an opinion, here. For close to the same money you can get a BAP engine with virtually all new parts. For $1299, it's worth it for the parts. Even to break it down and go through it for yourself. Check out their website.
Old September 21st 2003, 16:17
57Drag's Avatar
57Drag 57Drag is offline
My 2 cents is to gather parts and build it your self,start small,stock build then mild build next time,and then build yourself a stroker...Donald..
57 Drag
http://photo.starblvd.net/57DragVW
