Old August 21st 2003, 22:42
craazy Cooter's Avatar
so many cams....
I'm going to rebuild my T1 1641cc in the next few months, and I need some experienced advice from YOU! 69x87mm engine size, 40x35mm 042 heads, dellorto dual 36mm drla's, 009 dist. Full flow oil system. What cam? I think split pattern cams are a technological advancement, so eagle cams from C.B. performance
are what I'm looking at. Any good rebuild kits to reccomend?
Are windage pushrod tubes any good? this thing will need to be
reliable, for 25 mile commuting, but I will take my chances, as I am an ASE master tech. haven't been stranded in a long time, if you know what I mean! Thank you so much for your replies.
cal look sucks...
