Old August 29th 2003, 17:00
Stuart Stuart is offline
Question Remmele rear coilovers
I've bought some rear adjustable coilovers from Remmele for my 1979 "vert". As I was installing the parts I was wondering if I could use the original VW bolts etc to mount the setup to my VW. As I'm using alloy 944 arms that use a M14 bolt on the lowerside of the coilover I'm not worried over the strenght. But on the topside of the coilover there is only the VW M12 bolt that holts the coilover to the body. There must be a big load on them as the total weight on the back rests on them. Is this strong anough? Shoud I buy stronger bolts? Help welcome.
Old September 1st 2003, 04:50
Re: Remmele rear coilovers
Originally posted by Stuart
... There must be a big load on them as the total weight on the back rests on them. Is this strong anough? Shoud I buy stronger bolts? Help welcome.
Total weight? What did you do then to the torsion bars? Remove them or slacken them one or two splines?
As for advise on the bolts: What has Remmele say about this? Surely when you purchase items from him, he will aswer your q's readily.
Old September 1st 2003, 21:22
SuperRSi's Avatar
SuperRSi SuperRSi is offline
pictures...
I sure would like to see some pictures of the entire coil-over set-up BEFORE it is bolted on. I also am very jealous that you got something you ordered from Remmele. Please post some pictures of both sides of the set-up (inside and outside).
Randy
Old September 2nd 2003, 09:21
Alex's Avatar
Alex Alex is offline
There are quite a few pictures of the setup in the suspension gallery of the coilover and the springplates.
Old September 2nd 2003, 15:46
SuperRSi's Avatar
OK, how about uninstalled pictures...
I would like to look at the units when they are not attached to the suspension. i.e. sitting on a table top. Everything I have found on this site shows them installed. Am I wrong?
Randy
Old September 2nd 2003, 16:49
contact with Remmele
It seemed that the most of the personel of Remmele is on holiday so I had problems to reach them. After sending some E-mails no reply. Todat I send in a fax and 30 minutes later I had mister Remmele himself on the phone, what a service!!! He told me that it is no problem to use the original bolts. In all those years he has not heared of problems with these bolts. As for Rsi, my setup is already under the car so no luck with the pictures. I only can make them on the car. In about one week I can make the pictures because then are the longer springs in house that Remmele wil send me. Can you wait till then? I needs those longer springs because the coilovers are bolted to my "vert" that is heavy on the backside.
Old September 2nd 2003, 17:30
SuperRSi's Avatar
no problem on the wait.
Randy
Old September 2nd 2003, 18:20
Racelook's Avatar
Racelook Racelook is offline
STuart do you have any pics of your car....
SO I can recognise your car at some Kevermeetings!!!
Greetingz from Holland
B-Extreme B-Tuning.....
Old September 2nd 2003, 18:30
Alex's Avatar
http://www.germanlook.com/Functions/...mages/0136.jpg
http://www.germanlook.com/Functions/...mages/0537.jpg
Both not installed.
Old September 6th 2003, 09:58
elroocky's Avatar
elroocky elroocky is offline
new model
hi
as Stuart said, all remmele personnal was on holiday in august, Eric the sale man has quit the job, him and beetle was not fitting, he's most a guy looking on japonnese tuning rather than beetle, and he didn't know a lot about beetle.. and durring the time I was there ( 8 days) remmele did not answer the phone, only on is private line.
since the 1 sept there is a new sale man, a french guy, he speak's german without any prob... but he's a sh** in english.. that's not a prob, because beatrice (eddy wife) will answer you for all of you from UK and US.. and other.. country's.. no prob..
by the way find joined the last model of coil cover... second generation..
[IMG]coil[/IMG]
ride a type4.. it will change your life.....
Old September 6th 2003, 12:22
Tim Tim is offline
Any idea how much it is?
Tim
Old September 6th 2003, 16:55
price
If you mean the price of the coil overs, it is 700 euro's.
Old September 6th 2003, 17:42
Tim Tim is offline
Sorry, I mean the price of the 935 style spring plates.
Tim
Old September 6th 2003, 22:21
Alex's Avatar
I think it is the about the same price.
750 Euros.
Old September 7th 2003, 03:20
Any idea what price MBT is offering their 935 style springplates and coilovers?
T4 2666 1303s
