Old September 20th 2003, 00:33
vwdave vwdave is offline
996 brake size- help!
Hi guys,
Does anyone konw what size rotors the front 996 brakes use?
Any idea on piston sizes for the calipers?
Thanks in advance for the help
Dave
Old September 20th 2003, 09:51
Superman
Hi vwdave, I see this is one of your first posts here so let me say welcome.
If you look around this forum you may notice that I answer a lot of these types of questions but I wanted to let you know that I can't here.
Just so every one will know my research is soley based on the 924/931/944/951/952/968 because they share the same suspension as the 113 (Super Beetle 1303).
I haven't really looked into the other chassis/brakes much so I can't answer here. My point is that I wish I could help but can't and wanted to let you know so you didn't wonder why I didn't answer.
Old September 20th 2003, 16:45
I beleive the base 996 uses 318x28mm front rotors and 299x24mm rears. Not sure on the piston sizes for the calipers though.
Old September 20th 2003, 16:57
Superman
Sandeep, I looked your information up in the MBT catalog and you are correct but they don't list pistion sizes either.
Old September 20th 2003, 18:54
yep, 318mm x 28mm seems familiar, now that i think about it. I wasn't sure whether the rotor was 28mm or 32 mm thick.
Thanks Sandeep, and thanks for trying Superman; at least I'll know that if you had have known the info then you would have been kind enough to share it with a fellow germanlooker, even if mine is a standard not a super!!
Dave
Old September 21st 2003, 12:57
Superman
Thank you and yes I am here to help, no matter what Type or year you have. I'm not one of those closed minded people, I love all VW, Porsche, & Audi cars and devote my spare time to helping our community.
Old September 23rd 2003, 05:24
By the way guys, I just found out that the piston sizes are the same as 944 S2 Calipers, 36mm and 40mm.
Later
Dave
