Old September 27th 2003, 21:50
oldyeler oldyeler is offline
Question on T-4s
What was the first year that VW Produced the hydrolic T-4 engine?
T-4. 2.0 w/t 36 hp upright DTM Going In a 356 Drauz , automatic , 1970 VW Kitkar pictures at Http//home.earthlink.net/~oldyelerbh2
Old September 28th 2003, 14:41
Massive Type IV's Avatar
1978.....That year and thoise thereafter were nightmares becaus eof them!
Jake Raby
Old September 28th 2003, 16:03
bugsoup bugsoup is offline
Is there a reliable way to add hydraulic lifters to a T4?
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
Old September 28th 2003, 21:57
reply on Hydrolics
Yelp I here that every where I ask.
The heat Just kills them.
But if I understand correctly they make decent solid lifter engine builds with a little work???
As I under stand the lifter bores are sleeved to except solids , Are they better or worse that way??
I have another question, Has an one ever seen push rod tubes made out of fluted alumium , with double seals on the ends or is that engineering overkill.:silly:
Old September 29th 2003, 19:11
kdanie kdanie is offline
If you use type 4 solid lifters you don't need to bush the lifter bores.
Many people dislike hydraulic lifters, others love them. I don't think it's the heat that kills them.
Pushrod tubes with double "O" rings and "flutes".... I assume the flutes are for cooling, probably would not accomplish much. Double "O" rings... might be a good idea.
ken
Old September 30th 2003, 02:10
I would stick with solid lifters. Lot more cam choices, along with less failure. Not to say a hydraulic T4 will always fail, but I've never heard anything good about them. Adjusting valves isnt that hard, I rather enjoy it.
=EuroLook71=
71' Super Beetle
Old September 30th 2003, 10:17
I agree on the solid lifters, it proven. and I also think if there is enough bore surface in the tube bores , a double o-ring setup would help a bunch.
Got another brain f-rt?
In early Prat & whitney radial engines I understand they use to coat and cook the jugs and piston with Tung oil to seal the metal pores of the parts to make them slicker and run cooler.
Has anyone ever heard that one before ???????????????
( break out the Formbey's tung oil furniture polish)
Old September 30th 2003, 17:09
Or you could use some snake oil Both withstand heat about the same I would guess. Guess is the key word here. Don't let that GL Guru by my name fool you!
Ron
