Old October 4th 2003, 15:55
gkafer gkafer is offline
944 brakes on bay window bus
Hi guys,
Looking for some help on a brake swap on a 1969 bus. I know i have the correct spindles as they use the same bearing as the 944 and maybe 911. What i need to know is what year 944 brake hub rotorwill i need? do you need to make some sort of bearing spacer? I will be using a non porsche caliper, i'll fab a mount for that. If you have info on using the porsche caliper i can use that as well.If you have any info (more detailed the better) it would be greatly apreciated.
Thanks!
