Old October 19th 2003, 17:20
Stuart Stuart is offline
gearbox stiffening???
Bought a 2,4 (160 bhp) T4 motor for my 1979 "vert". For this moment i want to keep my standard gearbox till I have saved some money to go a step further. Are there things to do to stiffen my standard gearbox. Help welcome. :silly:
Old October 19th 2003, 17:28
Alex's Avatar
Alex Alex is offline
Brace your frame horns either with the Käfer Cup Brace or with one of its copies. Make sure the tranny and shifter bushings are still good.
Hmmm what else..........take it easy on your tranny .
Old October 20th 2003, 04:07
Hi Stuart,
Congrets!
Making sure the engine is hung-up properly is key for now, since properly strengthening the box requires disassembly.
At least get a rear engine support bar and/or the brace.
Any more data on the engine would be nice! Who did you buy it from? Is it a used or new engine?
Old October 20th 2003, 05:59
Racelook's Avatar
Racelook Racelook is offline
Woww Stuart
That's the way to go!!!
Another bad *$$ kicking beetle in Holland!!!
Great job... Let me know when your going to a bug show.. so that i can see your bug in the real world..
Greetings Wiebrand
B-Extreme B-Tuning.....
Old October 20th 2003, 06:15
some specs
I've bought the motor finally from Klaus in Germany. After sending a lot of e-mails to the different tuners only Klaus and Hot Rod gave a good answer to my questions. The others didn't give a answer or just an answer like "yes we sell engines".
Klaus is not cheap but I visited his workshop/shop last saterday and he took plenty of time for showing his craftsmanship and shop etc. He has a whole range of parts designed by him fot the T4. Some specs from the new engine are 71 x 103 mm, 44 IDF, 44 x 38 valves with heads that are ported etc. Mild cam as this is not a high rev's engine. Stainless steel muffler. Torque is 220 at 3000 rpm.
Old October 20th 2003, 11:58
Alex's Avatar
You will be happy with your Klaus motor.
Great tuner with lots of attention to detail.
Old October 21st 2003, 17:53
Bruce2 Bruce2 is offline
All you need to do to your trans is put a better differential in it. At a minimum use one of the cheap aftermarket superdiffs. Better yet, step up to a ZF limited slip diff.
