Old October 26th 2003, 13:34
csp disc brakes kit
has anyone tried the csp disc kit? vented or unvented? how have you liked them? is the performance good? are these brake systems a obe off design or does anyone know if they were taken from another pplication ie. new vw, or porsche?
whats the pros and cons?
neil
Old October 26th 2003, 18:31
darren's Avatar
darren darren is offline
hi neil
from what i remember reading the caliper is from a ghia or a golf (rabbit). If you go for a vented kit then its the same caliper but it has been widened. The 4 pot vented kit is a brembo i believe.
darren
Old October 26th 2003, 21:40
Intresting. I didnt know that the calipers where just modified ghia calipers. Does anyone know if Topline offers the vented kit?
=EuroLook71=
71' Super Beetle
Old October 26th 2003, 21:53
Alex's Avatar
Alex Alex is offline
As far as I know the only vented kit is produced by Kerscher which many tuners sell like CSP. All other vented kits are true Porsche kits or kits that use the Boxster rear caliper with the Kerscher disk.
I might be wrong. Would not be the first time.
Old October 29th 2003, 10:05
zydeco zydeco is offline
Indeed they are - I purchased the vented disc kit through CSP's USA distributor. The calipers are Ghia with a simple, free-hand cut (read: cheap and quite unsightly) aluminum spacer that spreads the caliper across the wider, vented rotor. When I opened the box, I wasn't very impressed with it from an appearance point-of-view but functionally it should be sound (although, a little grinding was requried on the inside to clear the rotor). The only thing I'm concerned about it caliper flex under extreme conditions.
I figure I'll try these first and use them as a base comparison before jumping to Porsche, Brembo or Tar-ox caliper upgrades.
Brian
73 Superbeetle
