Old October 29th 2003, 04:02
clas73's Avatar
clas73 clas73 is offline
narrowed suspension
hello all,
I was wondering what the overall benifit is to having the trailing arms narrowed are ( a one inch tuck?) vs. going with wheel spacers.
thanks,
Charlie (CLAS73)
69' Beetle
71' Beetle
72' Transporter
Old October 29th 2003, 10:08
you would narrow your rear suspension for 1 of two reasons:
1 you want to run really wide wheels under the stock rear fender
2 you want to run a wheel with very little offset.
Unless you want to do one of these two, I dont see the benifit to narrowing the trailing arms.
With the right wheel offset, you dont need to narrow your suspension, but sometimes you may even have to run a spacer to bring the wheels back out some like I did.
I am running 7" wide wheels in the rear with a 10mm spacer because of the wheel offset I chose I needed to bring the wheel back out some because they were hitting the suspension.
