Old November 2nd 2003, 17:17
John John is offline
Loud front disk barakes
what do you all use for loud disk breaks? I put some lube on the back of the pads, I was told to put someother stuff on the pads them self. Any ideas? I am scaring other drives with the breaks screaming.
Old November 5th 2003, 20:16
yetibone's Avatar
yetibone yetibone is offline
Hi temp RTV silicone, like Permatex Copper RTV. It literally glues the pads to the calipers, and provides some cushioning to dampen the slip-stick-slip-stick vibration that causes brake noise.
Apply sparingly.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old November 5th 2003, 23:45
yetibone
Thanks for your reply. I bought new brakes. The vendor said I need to get new pads. So anyway I got the new pads installed and just as loud. I am so pissed. I will try your suggestion
Old November 12th 2003, 19:18
cormac163 cormac163 is offline
You could try copper grease it works brilliantly i used it on my super
Old November 13th 2003, 13:57
zydeco zydeco is offline
Don't forget to grease the pad carrier pins (assuming you're running Ghia style calipers). These can be a source of vibration and noise as well. I've used high temp synthetic grease with great success in the past.
Brian
Brian
73 Superbeetle
