Old November 4th 2003, 14:12
Bad bug's Avatar
Bad bug Bad bug is offline
2270 engine buildup
Hi guy's haven't posted here in a while, but my question is do you need to run none stock type 4 lifters when you upgrade to a 78.4mm crank. Also does the stock 2Ltr type 4 engine use lifter bore bushing when do you use these.
Old November 4th 2003, 17:23
Massive Type IV's Avatar
I run stock lifters in almost all my engines. tried the others, the results were not what I liked....
Stock or ceramics from LN Engineering.
Jake Raby
Old November 4th 2003, 17:32
Bad bug's Avatar
Thanks jake this helps me out alot since i was worried that i may have to do alot of machine work on that area.
