Old November 4th 2003, 19:16
bellcrank linkage and acc cable
for those running bellcrank linkage, where are you securing the accelerator cable housing? also, i assume the cable needs to line up as horizontal as possible to the linkage. this seems to put it right at the line of the front cooling seal.
lastly, what linkage is used to secure the cable to the bellcrank? don't seem to be able to find the parts in my parts box.
Old November 4th 2003, 22:02
Massive Type IV's Avatar
call me at the shop 706 219 4874. I missed you call on my cell.
Jake Raby
Old November 5th 2003, 05:31
petevw's Avatar
petevw petevw is offline
i would also like to know. it seems i'm only getting 1/2-3/4 throttle with the pedal fully pressed!
thanks,
pete
'72 super
'65 bus
'52 split
Old November 5th 2003, 10:05
I've converted to the bell-crank linkage and my accel housing (I made it out of aluminum stock) is bolted to the left top engine mounting bolt. Works great but I am going to re-work it so it looks better.
Old November 7th 2003, 10:20
well, so far i just snipped a bit of the front seal so the housing will nestle in it and on the top of the case. the bracket on the case bolt is a good idea. may try that.
