Old November 5th 2003, 17:30
jrinlv jrinlv is offline
Whats the best way to store Carbs
I just pulled some off an engine that was running, How should I prep them for a long store? They are Webbers if that matters... Thanks JR
Old November 5th 2003, 23:52
craazy Cooter's Avatar
Vegas should be dry, so I would spray them with wd40 and put them in big ziplock bags, with some little silica gel baggies, like the kind that come in new shoes.
Old November 7th 2003, 21:14
yetibone's Avatar
yetibone yetibone is offline
...and keep 'em some place that's temp controlled so condencation doesn't form in the jet holders, emulsion tubes, accellerator pumps, etc...
of course where your'e at that may not be a problem.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old January 1st 2004, 07:22
Paul Illick Paul Illick is offline
Most important thing is to get ALL the gas out or the insides of the passages and the bowls will corrode. And don't just turn the carbs upside down, take off the tops, take out the jets and and mixture screws and blow it all out. Then some WD40 or something and a dry place.
