Old November 20th 2003, 15:30
rear side air vents
ive noticed in recent mags. that most of the beetles have shaved /covered over the rear side air vents, behind the rear windows. is this a good idea? with out these wouldnt the engines heat up more? i guess if you replace them with something it would be ok..., but if not what are the side effects?
neil
Old November 20th 2003, 21:07
My 1969 beetle didn't come with those vents and I never had a problem with over heating. Some ideas would be to use deck lid stand off plates or a convertable deck lid. The convertabe deck lid has four patches of louvered vents to let cool air in. Hope this helps..
Old November 20th 2003, 21:46
they are most often deleted not only for athestics, but because stock they have a foam pad in there that acts as a sponge and causes extensive rust damage. therefore most people end up repairing the section and deleting them.
if yours are in good shape, i would clean them out and use them to feed the carbs. although i have to say i like the smooth look.
Old November 20th 2003, 22:53
my vents look great and are clean, i thought of adding the air scoops and using them to feed my carbs and fan to cool the engine. kind of a ram air on the side.
do the vents even lead to the engine compartment or would i have to route it there?
thanks
neil
Old November 21st 2003, 01:23
no, these do not go to the engine compartment, they are a fresh air induction, mainly to allow air into the inside of the car.
=EuroLook71=
71' Super Beetle
Old November 21st 2003, 03:22
juse's Avatar
juse juse is offline
NACA ducts
Take a look at these racers fom Great Britain. Notice the NACA duct on the upper surface of the rear wheel arch. They look good and quite effective to me.
http://www.jprmotorsport.com/
Justin
Old November 21st 2003, 04:59
Racelook's Avatar
Racelook Racelook is offline
Jep that's what i've heard to...
But some of the air goes to the engine compartment (if the foam is removed)
greetings Wiebrand
p.s. the mine are welded close for the looks..
B-Extreme B-Tuning.....
