Old November 22nd 2003, 03:28
factman factman is offline
T1 engine parts with forged 82mm crank
i was going to build a 2276 but decided to go t4 so here go the parts. i bought everything from aircooled.net and have reciepts for everything i think(atleast most everything if not everything)
all new parts, never out of boxes.
82mm crank 4340 forged ACN special chinese forging, usa machining
crank installation kit with straight cut gear-not helical
Kolbenshmidt main bearings std, std
Mahle double thrust cam bearings
straight cut cam gear steel/steel adjustable with washers
spiral lock piston pin keepers
web cam 86b with slr brazilian lifters
ACN alu pushrods( not cut to length)
1700 lb porsche style 3 finger pressure plate
dual friction disc(copperhead)
12lb flywheel forged
bugpack chromoly case studs
CB offset manifolds
VDO head temp kit
IRS rancho pro street tranny-3.88 R&P 1.48 3rd, .89 4th, alu side cover, welded 3rd/4th gear, superbeetle main shaft, super diff, steel shift forks, good drag and cruise tranny combo.
has nosecone for a 70 bug and has been installed but never driven a foot. put it in and then myseriously the engine wont turn all the way over when put back in after clutch job and im giving up on the bug to concentrate on my notch. just putting stock tranny back in.
if you are interested in any of this email me at factman@earthlink.net and we can work a deal. i would rather sell the engine stuff as a package but will sell individually. these are brand new never opened parts and i can take pics of anything you want to see. thanks.
SAM
'64 notch 2.5L T4
'70 bug 1776cc
Old November 28th 2003, 18:41
only tranny and pressure plate are left. thanks
SAM
'64 notch 2.5L T4
'70 bug 1776cc
