Old November 30th 2003, 23:16
Ephry73 Ephry73 is offline
Another alternative for 944 front calipers?
I was reading the 944 brake upgrade segment in this forum, and wanted to know if anyone had tried or at least measured this:
What if one can were to use the CB dropped spindle with CB's Rotor(non-vented) and a 944 single piston(read bigger than stock VW) caliper?
Will the offset not work in conjuction with the stockish rotor?
still have to drill and flatten the spindle to use the caliper, but if this is possible, then it will be waaaay cheaper than the CSP rotor set or similar....
ust curious since I already have all the parts, except the CB dropped spindle and rotor.
Ephry
