Old December 5th 2003, 17:39
vespaboy vespaboy is offline
Can I use 924 disk on
I have 72 standard and I plan to use 924 brakes disk in front and 924 drum in the rear...
Because it changes the bolt pattern...
Is this a good Idea and is it possible...
Thank you ......
HELP PLEASE>>>
Oh ,but it is so true though...
Old December 5th 2003, 17:51
63Rag 63Rag is offline
924 Porsche same as VW 4 pattern
924 is same bolt pattern as 72 beetle
It should be a straight swap 924 is thea same bolt pattern as Volkswagen, it was designed by Porsche for VW initially. The 944 came with the porsche 5 lug pattern. I have two sets of 944 brakes NOT a straight swap. One is for sale, Check out Sale section. Good luck
Wolfy
Old December 5th 2003, 23:28
no the pattern is 4x108 for the 924...
the 914 is the same as the beetle...
i just need to know if the disk will fit from a 924 to the beetle...
thank you......
i may be wrong so any info is welcomed......
Old December 10th 2003, 02:18
Superman
There are no real benefits in the 924's 4 bolt brakes, they are so close in specs to the Beetle and the oddball 108mm bolt pattern will make wheel fitment difficult.
Old December 10th 2003, 14:27
thanx for the info...
I just thought because it was easy to get these disc and that ford focus had the same pattern that it would be easy to find after market rims...
Were can I buy blank disc or some with other patterns?
Old December 10th 2003, 19:44
Superman
Drilled drums or discs, Topline Parts.
