Old December 5th 2003, 17:49
63Rag 63Rag is offline
924 is same bolt pattern as 72 beetle
It should be a straight swap 924 is thea same bolt pattern as Volkswagen, it was designed by Porsche for VW initially. The 944 came with the porsche 5 lug pattern. I have two sets of 944 brakes NOT a straight swap. One is for sale, Check out Sale section. Good luck
Wolfy
Old December 10th 2003, 02:08
Superman
The Beetle bolt pattern is 130mm and the 924 is 108mm. They are not the same. It is confused because the 924's 5 bolt pattern is 130mm also but it's 5 not 4 bolt. All 924 with 4 bolt wheels are the 108mm bolt pattern. Lastly, the car was designed by Volkswagen with Porsche influence late in the project.
