Old December 7th 2003, 17:46
VW911 VW911 is offline
911 alternator
1972 porsche 911 11-blade fan set-up
Alternator (Motorola) 71223702 14 volt
Regulator (Bosch) 0192062007
Question: How is the regulator wired back to the battery for charging from this regulator? Or should a different regulator be used? Set-up going in a 1970 ghia.
http://community.webtv.net/vw911/VWGermanLookPage/
Old December 8th 2003, 10:05
I've wired up a Bosch 911 alt, but my bug had the regulator already wired. Do a search on wiring up the alt ... the info is there. Hope its helpful.
Old December 8th 2003, 10:22
If you go to this pelican web site, there are 911 wiring diagrams posted. They look very similar to the vw's.
http://www.pelicanparts.com/911/911_...l_diagrams.htm
63 356b time capsule
948 project
