Old December 10th 2003, 12:19
hot66's Avatar
hot66 hot66 is offline
brake line size & fittings?
I'm at work so can't go in to the garage to check...
what size fittings & brake lines do I need for Porsche brembo callipers & m/c?
What flexi's are you all using?
thanks
project in progress
Old December 11th 2003, 07:32
Stuart Stuart is offline
As far as I can remember the brembo's have the same size fittings as the VW have.
Old December 11th 2003, 13:52
MattKab's Avatar
MattKab MattKab is offline
The Brembo's do use the same fittings as stock.
I'm using Goodridge SS which made no difference at the pedal to speak of.
Matt
Old December 11th 2003, 16:29
hot66's Avatar
are the stock fittings M10x1 ?
project in progress
