Old December 14th 2003, 13:42
Martice's Avatar
Martice Martice is offline
944 tach wires
Hi,
I have the 944 tach in the picture and I don't figure out how to wire it.
The problem is that it has 6 inputs and my last tach had only 3 (+/- and ignition coil)
Any suggestions would be nice.
Martin
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old December 14th 2003, 13:45
Martice's Avatar
hear is he front.
Oh, and does anyone know how to demount the tach? I remove the 4 screws on the back, the inside of the tach is loos but it seems like the tach its sealed...
M.
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old December 26th 2003, 11:01
COXBOW COXBOW is offline
Hi,
I’ve got the same gauges in my GL, the outer ring (Bezel) is “just” snapped on the pot, you’ll have to use a screwdriver to open it, they’ve just bent it over the pot!
Be very careful ‘cause I’ve broken a couple of them and it’s very hard to find new one’s (and expensive to! 25.78$ a piece!!!)
Serge aka Coxbow
Old December 27th 2003, 07:35
MattKab's Avatar
MattKab MattKab is offline
Terminal (4) is 0v, (5) is +12v and (6) is to the L.T. side of the coil.
The terminals are labelled on the PCB only.
I've never seen that yellow print
Matt
