Old December 18th 2003, 05:40
Stuart Stuart is offline
electrical safety relay
I,ve converted my super to a electrical feul pump. Now I want to install a safety relay so when the car comes to a stall with the ignition on the feul pump stops working. Does somebothy have a electrical wireplan for this setup. I know that Pierburg sells a setup but I want to build my own. Every help welcome.
Old December 18th 2003, 13:04
I've seen this done before but can't remember where. I beleive the fuel pump relay should be getting its power on connection from the oil pressure switch ... basically if the oil light comes on (stall, very low oil pressure) the fuel pump will shut off.
Check out a website for a company that sells electric fuel pumps (Holley ?) for the wiring diagram.
Old January 1st 2004, 17:36
CLKWRK's Avatar
CLKWRK CLKWRK is offline
I beleive the early rabbit fuel pump relay, had a coil input to shut the pump off when the keys were turned to the on pos but the car wasnt running. it also had a built in fuse holder.
hope that helps
B
GL ghia restoration:
