Old December 19th 2003, 00:00
Post Front Ducting... good or bad
So here is the deal...I want to run a front bumper/spoiler for my car (see:"My surgery ideas" thread in the fiber forums). In the center of the bumper I want to use an oil-cooler, and am worried about drag created by the dead space behind the cooler. I have came up with an idea, by placing ducts in the shape of the bumper opening and running it though to the hood. I have been told this may create lift in the front and I am worried about this.
I would like some input/opinions on wether or not this would create lift, downforce, or wehter it would just be a big void in the front....any one have experience with this kinda stuff? HELP!
John
VolkSport Kfer Gruppe
www.VolkSport.net
Old December 19th 2003, 00:13
Hmmmmm.
If you are letting the air out from in front of the car via a duct going to the hood that shouldn't create lift. With all that hot air escaping out the otp of your hood it should at least defrost your front windshield in the winter.:silly: You might want to look at a second generation 1986-1991 mazda RX-7 oil cooler. It is about 22" wide, 4" deep and 5" tall. That should fit nicely in the front of your car. Oh ya, It looks like it will add at least a quart of oil to your cars capacity.
Old December 19th 2003, 00:20
Thanks, Brendan, for the posi feed back, and thanks for recomending the second Gen RX-7 oil-cooler, I'll see if I can't find one on ebay...
Oh Yeah! I like the defroster bit, LOL!
John
www.VolkSport.net
Old December 19th 2003, 00:33
I had one. It was on my RX-7 untill it blew up.
Stupid rotarys:hurl:
Old December 19th 2003, 10:35
im sure with running the oil cooler to the front of the car, he is going to be adding alot more then just one more quart of oil
Old December 19th 2003, 11:18
explain the ducting method you have in mind. i am assuming a wide channel cutting all of the way up. or are you thinking just two tubes?
Old December 20th 2003, 06:01
vujade: OH YEAH! Try about 10 or so (just a guestiment)
Sorry botu the RX-7 Brendan, rotary is completely different....
zen: Ok, you kinda know what I'm planning on doing, as I have explained in my e-mail. Well it's hard for me to explain by typing and not being able to lay it down on paper, and the channel is what I was planning on doing....but here it goes!
If you read my thread in the fiber forums you are probably familiar with the bumpers I am looking to use. Each bumper/spoiler has three main openings (one big opening in the middle and two smaller openings off to the sides) allowing me to use ducts to my advantage. As I stated before, I will be using an oil-cooler in the front center opening of the bumper. To avoid this opening from causing any trouble in aerodynamics, I chose to duct the air through the front, past the steering componants (depending on how the bumper sits on the car) and the trunk space, exiting through the hood...Now on the hood opening I was thinking in terms of a canard style wing, small yet will create downforce.
Thats about as much as I can elaborate right now, I do not have a front bumper to work with YET! I will be getting one in the near future as soon as I chose the right one. I promise to update everything that I have been lacking in a.s.a.p.!
I hope that clears it up for everyone a LITTLE bit, sorry I give you more... next time
John
www.VolkSport.net
Old December 20th 2003, 19:41
I meant at least one quart of oil for just the cooler.
Old December 20th 2003, 20:01
njv's Avatar
njv njv is offline
hi
very rough rule of thumb you will need a litre for every meter so long as your using a decent size cooler line !!.
have you guys seen the nice oil line holders that bolt to the pan to body screws under the car you send one line up one side the return down the other ill try and find a link if your interested .
neil verdon 66 sqr on irs.
Old December 20th 2003, 22:27
I'm interested, rather curious as a matter of fact. Let's see what you have for us...
I was thinking about running the plumbing through the heater channels (since I won't be using them), what about that?
John
www.VolkSport.net
Old December 20th 2003, 22:33
I would use hard metal lines to prevent chaffing that could cause an oil leak.
Old December 20th 2003, 22:37
I'm gonna, steel braided is the only way to go when doin this
John
www.VolkSport.net
Old December 20th 2003, 22:55
Even that may chaff. I was thinking you could use large diameter copper plumbing pipe. If you can find it you could use aluminium pipe.
Old December 20th 2003, 23:16
3MCRacing's Avatar
3MCRacing 3MCRacing is offline
Just as few thoughts, questions and ideas.
question Is the oil cooler going to be in an enclosed area ?
If yeas then just use the ducting to put the air flow out of the wheel wells. The air is already going to be there so using the ducts this way will not cause lift. If the oil coller is not going to be enclosed then then the air will travel under the car and this might cause a little more lift then normal (Depending on Speed) The best method is to enclose the oil cooler and use the duct work to cool the brakes even if the other two holes are used for brake ducting.
Michael
Old December 20th 2003, 23:55
3MCRacing: Nice avatar man...kinda kreeps me out
Thats an interesting point you have there, I don't quite follow you on it. Have you seen the bumpers I was talking about? I also was looking at a few Porsche bumpers too.
Would you beable to elaborate on you idea for me a little?
Check out the Fiber forums to see my bumpers.
Brendan, you have a good point, I never knew steel braided lines would chaff, maybe some chromoly tube stock or aluminum like you said. I could then run some steel braided hoses from the cooler to the tubes and fit them together with some AN fitting, but what size of tube stock should I use?
John
www.VolkSport.net
