Old December 24th 2003, 19:44
Panelfantastic's Avatar
Arms, Arms, Arms!!!
I finally got my narrowed IRS arms in today! Woo Hoo! Will be doing a little preliminary fitting this weekend and will post some pics. Lots of fabrication to do but finally moving forward!
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old December 24th 2003, 22:01
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Where'd you get them from?
Old December 24th 2003, 22:27
www.blindchickenracing.com
They are tubular chro-mo, narrowed 1.5" with a custom springplate mount moved in 2".
VKG Bastage child
Old December 25th 2003, 15:48
roo roo is offline
I'm assuming these are similar to the ones available at aircooled.net. or not? Is it possible to move the shock mount as well as the spring plate mount? well in my case it would be a coilover mount but i'm curious. also how much did you pay if you don't mind saying. thanks.
Old December 25th 2003, 20:23
Re: Arms, Arms, Arms!!!
well Merry Christmas to you!!!!! be sure to hit us with some pics as they go on.
Old December 26th 2003, 09:34
Roo,
Sent you an email.
Zen,
YEESSS! Christmas indeed! Will definately post pics as I can.
VKG Bastage child
Old January 8th 2004, 15:54
miller's Avatar
miller miller is offline
Hey can I get some pics too. I talked to the guys at blind chicken racing for tips on 2.3L turbo stuff. Really nice guys. Im wanting to sjee those narrowed arms too.
Old January 8th 2004, 19:35
roo roo is offline
hey panalfantastic i already posted it under narrowed irs but wan't sure if you knew. i did the measuring and for an irs car narrowed 2" per side you can move the pivot (hiem) back 9/16 and it should have the same geometry as stock. hope this helps. and also i decided to opt for stock arms as i don't think i will be narrowing the track any just the spring plates. cheers
Old January 8th 2004, 20:05
Thanks Roo! Luckily, mine has bolt-on IRS pivots so I can set my ride height and dial in the perfect camber.
I just posted a bunch more pics on the samba under Jeff K. so you guys can see how things are shaping up...
This is my favorite,
http://www.thesamba.com/vw/gallery/i...oto+135755.jpg
VKG Bastage child
Old January 9th 2004, 01:00
roo roo is offline
well thats what i was getting at when you mount your hiem it should technically be moved back 9/16" from the center of the tube but i'm not totally convinced it won't work in the stock location. that thing looks killer by the way.
Old January 9th 2004, 02:24
miller's Avatar
How much did they charge for those arms? Keep us posted on how it handles and whatnot.
Old January 9th 2004, 09:10
Aircooled.net has them for $425 I think. Should be in stock, ready to ship.
Roo, the key is making sure the two pivot points line up. I made a little jig that fits into the inner pivot and lines up the heim. I hope it works like I think it will.
VKG Bastage child
Old January 9th 2004, 10:46
Racelook's Avatar
Racelook Racelook is offline
Talking
Panelfantastic
Your narrowed arms and hole your bus looks verry cool and smooth..
Keep up the good work man.
Wiebrand
B-Extreme B-Tuning.....
Old January 9th 2004, 19:26
roo roo is offline
yeah the two pivots have to intersect. i measured the trailing arm pivot and it has a pitch of 9/32" rise per inch. so if you narrow 2 inches (2" * 9/32" = 9/16") so if find the center of the torsion tube mount the hiem 9/16" towards the rear of the car from that and they should intersect. cheers
Old January 9th 2004, 20:01
DORIGTT's Avatar
Question
Panelfantastic, roo, did I miss something? Are you guys referring to mounting the heim joint for the trailing arms offset so that binding doesn't occur?
